Mark, yes, a personalized instructor. At the KYPCA event, there was an instructor assigned to me. This instructor had a Cobra Mustang, which, broke down early in the day, otherwise, we would have had several lead follow sessions. He did observe my track sessions and provided welcome feedback after each session. When I spun (2 times) he walked me through the corners (figuratively) to make sure I understood I recognized what went wrong. He also provided some opinions on handling adjustments, driving adjustments and air pressure recommendations. The morning of the 2nd day we walked the track. We drove to each corners' entry and exit as he explained the line through the turns. This was most helpful understanding an on camber and off camber turn as well as the exit strategy for the turns.
I can't stress enough to those of you that are timid on our cruises what a great experience a track day is. You do NOT need to set course records to have fun. Since my first run at Putnam to my last, I have shaved off about 10 seconds per lap, and THAT is great improvement and I've learned a ton about the car, and myself. Having fun is the main goal, don't mean to poopooo on the lateral g meter, but that should be the least of your concerns, how many g's you are pulling through the turns. Just have fun, use the car it and YOUR fullest extent. The rush of going through a corner at a speed you are not comfortable with, but making it because you drove the line properly is awesome, and cannot be matched on the street. I hope more of you can make it out to these events, and if you need help preparing, let me know.
Back on topic - I will be traveling down to San Marcos, Tx for the Texas Cobra Club big shibang, which includes a track day or two there. The early May event with 10/10ths sounds good, and then on to Hallett. So, I will have 3 events in before the end of June
Gateway, yes, there is a lot to hit. YOU have to recognize this and drive accordingly. Even if you are the fastest, you get no trophy, no money and barely get bragging rights. So, if you aren't comfortable approaching turn 1 at 120mph, don't. It's that simple. These cars, if setup somewhat responsibly, will handle what you throw at it. Don't drive above your means and do not drive above what the car can deliver. Simple. Use the K.I.S.S. method and do not ever enter a track scared. Respect it and you will be ok.
As Steve has always said, these track days are much more fun when several attend. Craig, Putnam is only 2 1/2 hours for you, and you can register for a one day of the event. Leave late Friday, on the track Saturday, home by Saturday night at 8. Much safer track than Gateway. HTH.
