Two-cylinder 300HP engine: OPOC Engine
Member # 032
St. Louis (south county)
Mark
Patterson
Anyone seen this before? interesting.....
It's a two cylinder with four pistons delivering 300+ Horse Power
It's extremely small and very efficient and is presently in use in test applications.
The configuration below is equivalent to high performance four cylinder engine.
When doubled, it's an extremely capable 600+ H.P. engine
It's called OPOC (Opposed Piston Opposed Cylinder), and it's a turbocharged two-stroke, two-cylinder, with four pistons, two in each cylinder, that will run on gasoline, diesel or ethanol. The two pistons, inside a single cylinder, pump toward and away from each other, thus allowing a cycle to be completed twice as quickly as a conventional engine while balancing it's own loads.
The heavy lifting for this unconventional concept was performed by Prof. Peter Hofbauer. During his 20 years at VW, Hofbauer headed up, among other things, development of VW's first diesel engine and the VR6.
The OPOC has been in development for several years, and the company claims it's 30 percent lighter, one quarter the size and achieves 50 percent better fuel economy than a conventional turbo diesel engine.
They're predicting 100 MPG in a conventional car. To see a video, go here:
Opposed Piston Opposed Cylinder Engine
