LED/HID Headlight options
I still very much like mine. A wide broad beam is spread across the roadway allowing you to see any 'furry' friends on the side of the road.
Last night was the second time ever I drove my car with the new headlights and all I can say is WOW. They really light up the road.:)
I know this is an old topic, but did you guys go with the Morimoto Seal7 from the TheRetrofitSource and if so, did you get the anti-Flicker harness? The harness almost doubles the price of the headlights. Or di you go with the ones from Bagger with the halo?
No anti flicker either. My lights came with an anti flicker harness. You can have it if you need it.
Breeze Automotive has a good setup. Not the cheapest but highly regarded on the FFR forums
Tim let me know if you want the LED type I have. I'll send you the link. They are basically jeep 7" headlights.
I got mine from Breeze:
Thanks all. Do you know if the Breeze lights plug in to the Ford harness?
What started out as a simple replacement of my headlights is turning in to a full blown replace/rewire the front of the car. I plugged in the LED headlights that Scot handed me at the meeting, and they worked fine. I started looking at getting the DRL and turn signal wired in, and that's when the trouble started. The Passenger park light wouldn't come on, wiggled the connector and it flickered. Removed the housing and found that the ground lead had broken off the housing. This led to finding a bad wire in the harness....which, has now led to...well, you get the idea. :rolleyes: Found that Terminal Supply in Maryland Heights is no longer there, so, anyone have a line locally on weatherpack style connectors?
I have a couple different types on hand you are welcome to.
I have enough to do your head lights & turns if needed.
Either solder on or crimp style.
Wish I had seen this earlier, I ordered some from Amazon, if they don't work I'll keep this in mind
