Heat cycles
TREASURER & Web Administrator, Member # 019
Manchester
Proefrock
Just listening to Adam Corolla CarCast show with tire expert from Nitto.
He says when you heat cycle your slicks, when you come off the track, you should put your car on stands so there's no weight on the tires . They will need twice as long, unloaded as you were running to properly cool down. Don't so this and they will flat spot and wear unevenly.
This only applies to slicks or tires made of race compounds.
FYI
Never got mine that hot, but guess it makes sense. My pit crew, me, doesn't want to work THAT hard :D
All my years running local and national races I have only seen go karts on a stand. Never seen a real car on stands between runs, after the race, or overnight. Many of these cars are running compounds softer than anything that Nitto makes.
