Bulb Seal
Tony_G
Member #077
Paid Member
O'Fallon
Tony
Goebel
Does anyone have any left over bulb seal? I need a little over 18" for some extra panels I made.
Thanks.
I believe I have that much. Will check on my return if Tim doesn't have it
Hmmm? Curious if anyone has additional blinker fluid...only need less than a pint and looking for some white grease to use on my bumper speed bolts.....BULB SEAL, you guys funing me right...?
Couldn't find it Tony...sorry. Will keep looking though just in case someone else needs. You check with Taylor or Tom Mc?
Thanks for looking Tim.
I have some extra Blinker fluid you can have Ian. Just use it sparingly. You don't want to have overactive blinkers. :)
I believe I have 18" of Bulb seal that I can bring down this weekend if its still needed.
That would be awesome Josh. You coming to the chicken run? Let me know what I owe you. Thanks.
Thanks again Josh
Thanks again Josh for the bulb seal. I finally got the little panels installed today. Here are some before and after shots.
Looks good Tony.
Seal it up tight, because the water will find a way to get in and soak your back/side. The tire will throw it in there pretty good!
Also, that bed liner you coated the panels with, I would coat the fender wells on the body with that stuff too. I used the rubberized stuff to help absorb the blow of rocks.
That's the plan when the body comes off for paint.
