Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Todd I agree. I found a article about shaving away some pad area to change the bias. They took out about 50% of the pad material and only made a 15% difference in torque. So while the surface area of a pad makes little difference, there is a difference. From their testing for every 3% change in pad surface area you will see a 1% change in torque applied to the rotor.
Todd, a little background as to why/how this discussion started. Not sure how familiar you are with the "cobra"/ "daytona" coupes you are, but basically, we are finding more weight is distributed to the rear of the car - mine for instance is 57% rear to 43% front with my big block. I believe Mike's coupe is close to that as well. The theory Mike is working towards is a 60/40 rear biased brake setup. His thought is more weight / bias to the rear means more even braking. I somewhat agree with that, but lean more towards being front biased since there is some weight transfer to the front plus forward motion equals more weight on the front during hard braking.
The objective for us both is to not have the back end of the car swap ends under hard braking in to a road course high speed corner. Mike and I have been back and forth on this, with some great discussion and I know I've learned a lot, but would be interested in your thoughts as well. We all know center of gravity, type of brakes, and tires all have something to do with braking successfully, just looking for that balance (I am anyway) for street and track if there is one. Thanks for checking in with us.
It doesn't show or ask the pedal ratio and every car is different. My Wilwood is 6.25:1 Some Mustangs are 5:1 It affects how much force is applied to the master cylinders.
It also assumes a single master cylinder, which many of us have dual cylinders of different sizes.
It's a good resource, just wish it allowed full "tweaking" to match individual cars instead of using some default settings.
