DESCRIPTION
Factory Five MKIV Roadster (Milano)
CHASSIS & BODY
- Body & Frame:
- Factory Five MKIV Roadster
- Front Suspension
- Dual A-Arm with Coil overs, VPM front swaybars
- Rear Suspension
- IRS with Ford 8.8 Pumpkin housing 3:27 rear gears and solid bushing mounting. 600 HP upgraded rear half shafts, 11.6" rear rotors with 4 piston Wilwood brakes and drum style E-brake.
- Brakes
- 6 Piston Wilwood Brakes on 13" rotors for the front and 4 piston Wilwood brakes on 11.8 rotors for the rear with integrated drum e-brake
- Wheels & Tires
- FR500 Deep dish Aluminum rims with 315/35 R17 on Rear and 275/45 R17 rims on front
- Color Details
- Lexus Ultra Sonic Mica blue with Ford twister Orange stripes
- Painter
- Body work by Tony Glover and Paint by Shane Hensen
ENGINE & DRIVETRAIN
- Displacement:
- 347 Big Bore (600 RWHP)
- Engine Family:
- Dart SHP block with 8.2" deck,
- Induction:
- Vortech V3 Supercharger, Treadstone Intercooler, Holley EFI with HP+ ECU and 1000 CFM throttle body
- Valve Train Details:
- 195 Comp AFR heads, Custom ground cam
- Ignition
- Holley Dual Sync used as a Cam Sync with Holley Big wire Coil on Plug
- Exhaust
- FFR 4 into 4 headers and ceramic chrome coated sidepipes
- Transmission
- TKO600 RR with .82 5th gear
INTERIOR DETAILS
- Interior Details
- Grey Wilton Wool Carp throughout, padded Grey leather and Aluminum custom dash with leather back bulkhead and center console arm rest and cubby hole
- Heater
- Yes
- Heated Seats
- Yes
- Soft Top
- No
